Hardwire a plug in shop heater?
toddt429
I have a shop heater that has a plug. It's a 240v 4000 watt heater. Any issues with hard-wiring it? I don't have an outlet in stock here. It's going to be fairly temporary. I feel like it shouldn't be unsafe to do so. Just want some opinions if I could please. Thanks.
Todd
BrandonV
Arizona
Realistically depends on what the manufacturer calls out. Is there a reason you can't just buy a receptacle online?
The Cobbler
I think by hardwiring it you are calling it a permanent installation, cabtyre is usually not permitted for permanent installation , and probably the heater isn't rated for it either.
can you/ will it work? yes
should you? probably not .
u2slow
BC
Wouldn't bother me in my own shop one little bit.
My heaviest shop branch circuits are 30A, so I won't hesitate to use a 4-5kW heater on a welding circuit, taking advantage of the common 6-50p plug. Or a similar approach with the dryer receptacle and cord whip salvaged off a dead appliance.
mike93lx
Richmond, VA
I'd be fine with it in my shop too, but I'd want some form of strain relief for the cord. If really temporary, a NM clamp would do it
T
toddt429
I'm sorry, I wasn't clear on that. I wasn't planning on just cutting the plug off. I was going to run 10 wire from panel to heater.
T
toddt429
I wasn't going to use the original cord. I would run it from pannel to heater and did plan on strain relief at the heater.
