Heater duct sagging from joists
Moosefire
Detroit
So I'm working on my basement and realized most (not all) of the ductwork is hanging from my joists by maybe 1/8 to 1/4 inch... is this normal? Maybe to prevent noise transmission through the house?
Or is it just that they've sagged over the last god knows how many years and just need to be hammered back.
Thanks for your help!
Sent from my SM-N960U using Tapatalk
Moosefire
Detroit
Here's the pics2c9581b13611a066ca3a6476ae724030.jpg0d3b1cad4a6cd7c40cf88bdfa6a3d24a.jpg
wanderer
I don't think you want them touching, condensation might damage the joists.
ezridr60
Iron River, MI
I’d get them pounded back up, screws would be better. Before you get something like this. Most of the duct work in the basement came down. $2,200 to replace!
SGKent
Citrus Heights CA
I'd have someone heavy walk over those areas while you watch from below, and see if the floor and unit bounce enough to be the force behind the nails moving out. I wouldn't think the air coming on and off would move it that much.
brewchief
Nails pull out from age, I see it all the time, supply duct should be 1" from the joist and the return can touch the joists.
I pull the nails and replace with a 1 1/2" or 2" screw.
Moosefire
Detroit
This i one application where, IMHO,a thoughtful installer would have used screws.
I'm guessing this ducting is original to the house, which was moved here in the 40s or 50s. Naturally I dont know but everything down there is old as sin
The Cobbler
I'm thinking they were done like that originally to reduce creaks & pops etc from the joists moving when walking over. the duct can sort of float . not a terrible idea, no need to worry about it falling or anything.
When this ductwork was done, driving screws was done with a tool called a screwdriver , held in your hand. much easier to nail.
santagary
Pagosa Springs, Colorado
Could be the weight of accumulated dust and dirt in the ducts also...ask me how I know?:confused:
Showkey
"MEMBER EMERITUS"
Wausau WI
Back when that tin was hung, screws weren't even thought of for that type of thing, much less general carpentry.
Tommy
This ^^^^^^^^^^^
Back then they were driving screws with Yankee driver on that rare occasion.....slotted wood screw to boot making slightly more challenging.
brihvac
North Wilmington, Delaware
Pull the nails and screw it tight. If you look the hanger sticks up a little further than the duct. So if you screw the hanger tight to the joist you will still have a little gap between the duct itself and the joist.
Nails are how they did it years ago. You can also tell it's old duct work by seeing they used flat head sheet metal screws. Nobody has done that in many many years
