heating cooling
david baker
my truck is a 93 toyota pick up and this morning i overheated i have replaced the radiator the radiator cap thermostat and cant see any broken hoses at the moment with quick over view. but the underside passenger side of my truck is covered with fluid. not oil in fluid or visa verse. any ideas of what might of broken or be leaking? please help
Highbeam
Mt Rainier foothills, WA
How's your water pump? You'll need to figure out where the fluuid is coming from. There is a weep hole at the water pump shaft that will leak fluid slowly to tell you that the seal is bad. If it leaks out all of your fluid it will make a mess and then you will overheat due to lack of coolant.
