Heating garage in a rental.
mojo_13
Iowa
Currently moved into a place with an attached 2 car garage that is around 20x20 or so (just wide enough for 2 cars). I have been looking at getting a heater for it before winter gets here. It has insulation in the ceiling and the two sides that are attached to the house are for sure insulated the other I am not sure. Also if I go electric it only has 120v outlets.
I'm not sure if I want to go propane or electric yet. I have thought about getting a couple of these.
http://www.amazon.com/dp/B0002D0HOY/?tag=atomicindus08-20
But then I started doing some reading on this forum and the Mr. Heater Big Buddy heater looked pretty good too.
I would like to hear if anyone has any experiences or comments on these two heaters of if you have any other ideas for me. Thanks for any and all help.
mojo_13
Iowa
I was kind of hoping for something not so noisy but if it does the job I may not care. How are the fumes? Hoping to keep the fumes to a minimum, I hear the big buddy is pretty good at that.
mikeyr
Santa Barbara, CA
I used to have a kerosene torpedo heater, fumes were bad only at startup after 3 or 4 minutes you could not smell anything so what I would do is open the man door and point it out that door for 3 minutes and then turn it around into the garage, worked well but would not if its super cold outside. The fumes were not that bad that I could not live with them anyway. The thing was noisy but it only needed to run a short time to heat up the garage.
What I did and would do if I was you would look into a Hot Dawg or similar gas heater, you suspend it from the ceiling, run a gas line which you probably already have in the garage for the dryer anyway, plug into 120V outlet and take the heater with you when you move, its what I did and would do again.
mojo_13
Iowa
Unfortunately it is an electric only unit, otherwise i would be all over putting a hot dawg unit in. Are there any units that are similar that could run easily off of a propane tank efficently or 120 electric only?
PaulR
Hadley MA
I got one these in a big 2 car garage, hooks up to a standard 20 lb LP tank.
Cost $60-$90
Heated the place up great, then I got a little bit of fumes.
The trick I learned was to crack the door a bit and stick the tail end close to the door, fumes gone, heat retained. :thumbup:
mojo_13
Iowa
Cost $60-$90
How long does a 20lb tank usually work on something like that?
tncatadjuster
Memphis, TN
I have one of these and it works great, it is LOUD. I also have another that is quiet, I'll find a pic.
If it is freezing outside I can heat up a room in about ten minutes and then run it about once an hour. It heats the adjacent rooms too, I guess a tank will last a week if working 8 hour days. Used it on a rental house that did not have power.
mojo_13
Iowa
Do you happen to know what the model of the quiet one is. I know that I am being kind of picky on this heater but I'd like something that I don't have to hear/think about just turn on and be warm while I'm in the garage.
tncatadjuster
Memphis, TN
I bought it at Home Depot. I also purchased a 20 gallon tank so it would last much longer than the bbq one.
Northern tool has them too.
