Hello from Calgary
yyc_ranger_4x4
Calgary, Ab
Hey all,
I'm in the planning process of building a new garage. Currently I've got the garage my grandfather built 50 years ago. 6 1/2' door, 22'x24', not quite an 8' ceiling. There used to be a pit in the floor, but the walls were never re-inforced properly and they started caving in, which is now allowing the walls to move. There is a gravel parking pad next to the garage.
What I'm thinking right now is a 32'x25' garage/shop. 8' double door offset to one side, and the other side to be a work area (I may frame in for a single door just in case I want to add it in the future). I'm thinking scissor trusses for extra height. 2x6 construction, as much insulation as I can to keep it warm/cool as needed, exhaust fans for when welding, etc etc.
I'm not sure which way to go for heat yet, but I'm leaning towards a ceiling mount forced air. Maybe in slab, but all the necessary equipment takes up a good chunk of room.
When I get closer to building it, I'll post up the google sketchup drawings and plans.
Wingnut65
Tampa Bay, FL
Welcome to GJ, yyc. Sounds like your existing garage needs some TLC. Your enhancements shoudl be just the trick to get you the shop you want. Along with what you described and all the insulation, be sure to include more electrical and lighting than you think you will need and you may be close.
Good Luck on your project.
