Hello from under the snow in Alaska
Wandering
Western ND
I stumble into your board the other day. You guys are amazing. :bowdown: I have a little project of my own that I have started. Here is some of the fun.
Well here are some of the details that I have nailed down.
29’9” x 40 (it is 29.9 instead of 30 because that is where the sonatubes ended up.)
10 foot inside ceiling (heat is a valuable commodity where I live) plus I got a good price on the outside 10’ metal sheeting (free)
Two 9’ tall 10’ wide garage doors.
Greenwood model 100 wood gasification boiler, already on site
100 amp service; wire already buried.
Outside staircase to 15’ x 29’ 9” attic “clean room”
Inside attic ladder for going upstairs on cold nights.
4’ x 5’ attic trap door complete with reinforced hoist anchor for moving thing from downstairs to upstairs.
8’ x 5’ heavily insulated bathroom with electric heater.
Radiant heated slab
Hot water unit heater for garage
Hot water wall heater for upstairs
I am eager for your inspiration and insight so please share all you can.
W
Wandering
Western ND
It will be. Actually broke ground in October, then we had an early cold, as in 6 degrees Fahrenheit before October 15th. It was 20 degrees when I poured the tubes and made a small pad for the boiler. It is miserable to trowel concrete at 10:00 PM in a snow storm when it is 10 degrees. The upside is that you have a lot of time to “work it”.
When I get home on Tuesday I will shovel two feet of snow out and continue building.
W
Wandering
Western ND
Many miles later, the shop above will likely be the best shop I will ever own. Left Alaska in 2012. Then 10 years in Pennsylvania, now in my 3rd years on North Dakota. Looking for inspiration for another shop build in 2026.
nadogail
Coronado, CA
I too used to live in Alaska, I sometimes wonder how my life would have turned out if I had remained.
