Help ID these two "NASA" tools
airborne_j
Southeast PA
I bought a matco tool chest this summer and it wasn't fully cleaned out. there were a bunch of thermometers, magnets, and spanners which were in rough shape.
These two tools are stamped "NASA 419" and "NASA 440T"
Anyone have any idea what i've got here? Thanks in advance!
joel63
Central FL
the "T" shape tool is a point adjusting tool, used for aligning misajusted point contacts.
Milton Shaw
Joel63 is right on the first tool. I have one in my box that I use on point ignition systems when I run into them which is not very often. The second one looks like a nail puller but I cannot imagine what NASA would use it for.
MattVette89
SW Chicago
Let me double check the stamps. I find it impossible to believe these are associated with the real NASA.
There appears to be a defunct company called "Nasa tool manufacturing corp" from Ohio. If you look on eBay you'll find a bunch of older tools from them.
fufu83
How long are they? Look like adj tools for voltage regulators or gov on equipment and trucks
Bruce Lancaster
J 63 is right about the first. If you look at the second closely, you will see that its end is a flat slot, also for bending...likely for adjusting carburetor arms and such. There used to be whole arrays of benders like these, with shapes for adjusting different types of relay arms in voltage regulators, and a bunch of small but heavier ones for bending various types of carb and choke linkage.
WRENCH-IT-OUT
maryland
Nasa also made socket sets, this being a 3/4" drive with the original box.......please tell me this was contracted by NASA to be used to work on spaceships
southalabama
Brewton AL
Well. This thread was cool when I thought it was Neil Armstrong's toolkit.
Had never heard of a NASA tool company.
As far as Wollowitz. Potato based diet for the Russians gonna need a bigger tool to work on the space toilet.
twertsy
Reedville, VA
I've been remiss at loading the remainder of my catalogs and I do actually have a NASA Tool Company catalog in the queue. Here's some info.
a>
ttpete
Dearborn, MI
I'll also say they're for adjusting automotive electro-mechanical voltage regulators. Everything was adjusted by bending, point gap, spring tension, etc.
When I was in the business, we could do it, but preferred to just replace the regulator unless it was no longer available.
