Help installing Red head Drop in anchors
bubinga
I don't have the tool, but have a metal lathe, does anyone have the tool.
do my dimensions seem about correct?
Pictures show what I have, and proposed dimensions of tool I will machine from 1/2" stock.
thanks,
see pictures
You can use anything that will fit inside the drop ins. You don't need a special tool at work we just grind the threads off a rod to set it
danski0224
Near Naperville, IL
Oh, OK, but how far do I knock the slug down, till it stops?
l could just use a punch then?
l guess the slug would bottom when it hits the bottom of the hole.
Yes, you can use a plain old punch.
Yes, the slug will bottom out. You can hear and feel the point when it sets.
The tool does make it a bit easier because it provides a visual cue.
Probably the one thing that most do not do, but should be done, is to blow or vacuum out the hole after drilling.
bubinga
<<makes sense="">>Makes sense>>>
</makes>
well, im only setting 4 drop ins, no point even making the tool then,
thanks, I will be sure to blow out the hole.
Thank You
IUEC Medic
East Bay Area
I tend to drill the hole deeper than the length of the anchor, blow it out, and thread a nut to the amount of thread I want exposed. Hit it with a hammer until the nut stops it, then tighten the nut to seat the anchor.
Make sure that you thread the nut a few turns past the tip of the anchor, because if you hit the nut it will deform the threads.
The reason I drill deeper than the anchor is so when I remove what's anchored, I can cut the threads off and hammer the anchor to be under the surface of the concrete, and the hole can be patched flush and even.
bubinga
They went in OK, I just used a punch to set them.
The material was pretty hard in sections, and the holes were a bit oversize, but they seemed to hold pretty well, in spite of the fit being somewhat sloppy.
Sent from my MotoG3 using Tapatalk
bubinga
I don't have experience removing them, but I'd bet you could thread a slap hammer Ina and slap hammer them out.
Or thread a long piece of all thread into the hole, and put an impact socket over the all thread, and a washer and a nut to form a puller.
spike99250
Pottsville, PA
On a related question about these anchors; what if you ever need to remove them, an easy way? Assume just drill out?
You might be able to drill them out but I have yet to see anybody pull one out. If you no longer needed them, you could just fill the hole with grout or a product like Rock ite.
IUEC Medic
East Bay Area
When you set them... Drill deep enough to be able to drive the anchor below the surface...
I've removed a half set one once... Hit rebar and started spinning. It's a pain. If you do manage to remove the anchor, you will have done so by breaking off the metal pieces that expand to wedge the anchor by prying twisting and pulling.
FigureItOut
Bentonville AR
I don't think they'd come out, but if so you'd need to hit them IN first to get the wedge to let go.
Sent from my SAMSUNG-SGH-I337Z using Tapatalk
