Mr9two9
Hi guys ,sorry for the long post, just trying to relay as much info as possible... New guy here. I do light mechanic work in my spare time , and got tired of my sears compressor, so I brought a real shop compressor off cl. it works (saw with my own eyes) guy alleges it was hooked up to 220v. it was wired directly to a big on off switch he cut those wires (bx cable w/2 wires in it) sold it to me and off I went.
Now I can change a light switch/ electrical socket, can wire cars with no problem and the vibe i get from things is i could do this too, if I'm steered in the right direction.
My breaker box is at the front of the house, the compresser will be mounted at the rear of the house (21ft wide x 45 ft long) on the oppisite side, under the porch. I am including pix of the tag on the compressor motor, and my box..
Inside of my breaker box, there is one open slot. there is a unused 20 amp breaker on the left, and two of the 15 amp double breakers only have one line, so i could conslidate them opening up another slot, making 3 open slots.
I would like to run a line to the rear (outside) of the house and mount some sort of 220v socket so i could unplug the compressor and switch to a welder to be used at same 220v plug -welder is my next purchase.
What is the best way to accomplish this? Discuss at length.
