horizontallyopposed
Hi all,
I've searched through a lot of threads here (and pretty much reached the end of Google), and there are a lot of people talking about "high output T8" but very few that properly reference T8HO (where I am talking about either 44W 48" bulbs or 86W 96" bulbs). I have been looking online for either tandem 48" or 96" T8HO fixtures. T12HO seems to be much cheaper and much more available, although typically in the 96" size only.
Now as background, here's what I'm trying to do - living in Southern Alberta and with an unheated garage, we see temps of -10*F (-20*C) for a lot of the winter. I still need my garage at that temp, even if it's not to work on the car, but to wax skis. So I still need a lot of light at low temperatures. Unfortunately unlike many on this board who live in warmer climes, or have heated garages, the selection at Lowes and Home Despot offers precious little (more on that later).
There are T8 fixtures available with electronic ballasts that have a minimum starting temperature of 0*F, but they aren't the T8HO, just 32W T8 48" tubes. However every reference I've seen to HO electronic ballasts (whether T8 or T12) says their starting temperature is -20*F.
The other thing I'd like to try and accomplish here is to be able to install decent lamps with 5000K temperature and a CRI in the 90s (like a Colortone 50). Like many here, I feel there's no such thing as too much light, so I really want to be able to see well, and have enough light for work like car detailing, etc.
I understand that going to T12, HO is my only real option due to the changes in regulation. 110W 96" T12HO is an available fixture, for about $120 per fixture, but bulbs are a bit of a PITA.
T8HO in tandem 48" just seems to be unobtanium anywhere online in Canada. I found some in the U.S. but prices seem to be insane - like $300 a fixture.
Now for what is available in HO......
Lithonia UNS296HO120 (2 lamp, 96" T12HO) - $130 ea
Thomas Lighting STRIP-S-286HO120 (2 lamp, 96" T8HO) - $125 ea
And that's about all that's readily available in HO.
Now, as soon as I drop HO and just look at 32W T8, there are lots of alternatives, many with electronic ballasts that start at 0*F. Even Home Despot has a Lithonia TUNS-2-32-MVOLT-GEB for $90 (4 - 48" T8 32W tubes, starting 0*F) (which annoyingly even on their website they call a "high output" fixture - grrrrr). These are $90 ea.
An interesting alternative is that HD sells high bay Efficent Lighting 4 and 6 bulb 32W T8 fixtures with reflectors, but I worry at 14' my ceilings are still a bit too low for high bay. But at $130 for the 4 bulb, is an option and have a min starting temp of -22*F.
One of my wife's clients is an electrical wholesaler, so I'm sure I can dig deeper into ordering something, but as is obvious, I'm still unsure as to what I really need. Note I have purposely excluded T5 anything due to cost.
So with apologies for the bloviating, I appeal to the collective wisdom with these questions:
1) am I over thinking this?
2) do I need HO fixtures, or should I just put one extra regular fixture in and call it even? Will 32W bulbs suffice? Do you really get that much extra by moving from the 32W bulb up to 44W T8HO? I guess in reality it's moving from about 3000 lumens at 32W to 4000 lumens at 44W. Although lumens go down as CRI goes up. But it seems the difference on 1 4 bulb fixture is about equal to having 1 extra bulb in there. So for every 4 non-HO fixtures I put in, HO would give the rough equivalent on one extra fixture?
3) can I get the combination of low temperature performance in a fixture and color correct bulbs in a 32W 48" T8?
My sincere thanks!
Keith
My sincere thanks!
Keith
