Notch1988
I've had my radiant tube heater on a line voltage thermostat since day one but I decided I'd like to go to a 24v thermostat. 1 - my post purge on the heater will start working and 2 - the new thermostat uses WIFI.
Below is the wiring diagram for my heater. My thermostat is a Lyric T5. I will be running 18/3 wire as I have none ran now and will rewire the 120v to bypass the line voltage thermostat so I have power at the plug in all the time.
Looking at the wiring diagram, I'm assuming the hot side (red to blue) will go to the "R" terminal in my Lyric. Then I will run from the blue to purple side of the heater to the "W" terminal in the Lyric. For the "C" terminal in the Lyric I run to the yellow to green or GND terminal in the heater?
