Hey guys. I'm hoping to get some ideas, suggestions and feedback for my next project. Have a read and post some thoughts.
I am going to be installing a 100 amp subpanel in my attached garage off my 200 amp service. I have about 12 to 14 spots available in my current panel. I will be running #2 aluminum SER less than 100 feet to my garage. I will be powering a 220v Bendpak lift, a 220v welder and 220v plasma cutter as well as a few 110v receptacles. From that subpanel I will be running power out to my storage shed.
I will have a few outlets for some power tools, a light inside the shed as well as a flood light on the outside. I will also be housing my 5hp 80 gallon craftsman compressor in the shed. Its currently a 3 phase but I will be converting it to 220v single phase. I will be running 2 pvc pipes underground in a trench 18 inches below grade. One for my electric and one for my air lines. I will be running #6 thhn out to the shed through the conduit. I havent done any calculations to determine the size of the pvc pipe but I will be going larger than necessary if possible. It is my understanding that any outdoor receptacle must be GFI. Does this apply to receptacles inside a shed as well? How would this apply to the 220v power? Does it make a difference if the compressor is hardwired or uses a plug? I haven't heard of anyone running 220v to a shed before so if anyone has ideas id love to hear them. The inspector wasn't available when I went to ask about my permits so I need to put together a quick schematic to get all my permits filed.
Thanks in advance.
Thanks in advance.
