toyotadriver
- Joined
- Dec 30, 2010
- Messages
- 1,586
I have a newly constructed 30x40 shop building. Well insulated. Where I live we can get temps around 0* F but not for very long. I'm planning on the heat source for the shop building.
I was thinking of installing a 45k btu Mr. Heater vented propane heater. However, I've also been thinking about installing a 92%+ furnace and running ductwork throughout the shop. My concern is, I only plan to heat the shop to about 40-45 degrees all the time and then raise the temp to about 62 or so when I want to work out there. Depending on the amount of propane consumed, I may leave the furnace turned off from time to time. I doubt that the temp inside the shop will drop below freezing due to the ambient temps around here as well as the level of insulation and air sealing of the shop.
I read somewhere that a high efficiency furnace should not operate at temps as low as 40-45 degrees. However, I'm not sure if that's true or not.
So, can I install the high efficiency furnace as I want or should I look at the Mr. Heater instead?
I want this shop (and later the house when I build it) to be as energy efficient as possible. However, I'm willing to install the Mr. Heater if it is the better choice.
And, propane is the proper fuel for me for this location. I will not be heating the shop with electricity or natural gas.
