High Pressure Sodium Lights
Ezzie
Lake Chapala, Jalisco
I put a 70W HPS fixture up on the front peak of the shop a couple of years ago (about 30' up). It is controlled by a photocell to give me dusk to dawn lighting. Has been working fine all along but in the past few weeks it has started going through an on/off cycle on its own about every 2-3 minutes. By this I mean it will fire up, go through the warm up cycle for a couple of minutes and then shut down. After it has cooled down, will refire and go through the same thing again. Very annoying.
Is this just a bad bulb? I want to be sure before I get the ladder out and risk limb and life getting up to it in the winter (snow, ice, yuk). Anybody know what causes this with HPS lights?
walrus
Maine
Bad bulb, they cycle when they go bad. Hoist up the ladder and be careful
E
Ezzie
Thanks guys - I suspected that's what it might be. Just wanted to be sure before I play monkey boy in the middle of winter! Maybe I'll see if I can round up a friend with a boom truck.
BoydS
South of Houston
Could be the lamp, but I suspect the ballast is the culprit. Are you sure the fixture is mounted 30' up...? That's awful high for a 70W HPS, but if you're ok with the light output at ground level then stay with that fixture type. If the fixture is really that high and you need a boom truck to access it, I would just replace the whole fixture and be done with it.. they are not that expensive.
http://www.amazon.com/dp/B0002YPJRS/?tag=atomicindus08-20
Aceman
Eastern Oregon
I don't know why you think he has a bad ballast? When HPS lamps start cycling it's time to replace them. See for yourself, catalog page 30:
http://www.advancetransformer.com/uploads/resources/hid-troubleshooting-guide.pdf
motofly196
Washington
I know some others have given their answer...but I've been working on a city library replacing the same bulbs that you are...same set-up. We had a bad ballast in one of them. When the ballast goes bad on a High-pressure Sodium, you get nothing at the bulb. When the bulb starts to go bad, it will start to cycle on....flicker for a few minutes....then go out. It will do this intermittently. What I do is cover up the photo-eye with a piece of electrical tape (during the day), then wait for the bulb to warm up. I'm not sure if you've priced a HPS ballast yet...they are over $100. Get the bulb...:bounce: Then go from there. We got the ballast on a city rate $30...I couldn't believe it! Shoulda' bought two!!
Scott
79firebird
Victoria bc
looks like ballast as had that happen at my work to one out side at work 28 feet up 2 months ago. had a new bulb we tryed same thing. Just had to replace 3 ballasts on the one in the shop after 6 years. The ballast's are cheap my work just payed $78 each. Could also be the ignighter
Charles (in GA)
50 mi south of Atlanta
I too thought that 30 ft was very high to mount this. Even some poles are not 30 ft. I have a metal building shop, its 16 ft at the eaves, and 21 ft at the peak, and its darn high. Is this some sort of industrial building?
Charles
E
Ezzie
Charles
60' x 100' building. The eves are at 16'-6" and the fixture is at the top of a 60' truss in the front peak. Maybe it's only 27' - dunno - but it is a long way up there. The only way I can get to it is to put my 20' extension ladder in the bucket of the backhoe and do the monkey thing.
BTW - replaced the bulb and all is working fine.
Can't understand why people don't think a 70W HPS is no good at this height. Gives me a really nice flood over the whole front of the 60' wide building - perfect for my needs and not too wasteful of power. I have it on a photocell so it gives me some added security since the building is about 500' away from the house.
ironroad 9c1
Gum spring,VA
I have seen a guy on a A frame aluminum ladder in a POOL with water in it working on a electrical connection..lol had it on the wall in the meeting room at Anheuser-Busch down in willhamsburg,va.
Vicegrip
NoVA.
I have done that 100s of times working on lights in indoor pools. Still here and no:shocking: events
I have also set an A frame ladder in a shipping box that was lifted by a forklift to its full stroke. All the way up the ladder, clip off on the joist and then climb into a drop celling sitting on the joist to get to the machinery that was installed with NO thought to being serviced.
Used a 120V mig to weld up some stress cracks in a large roll door controller on Thursday. Hung it inside the peak of a ladder that was strapped down tightly into a proper forklift man work box and up into a ceiling. Just enough room and reach to weld up a poorly made frame work that held the controller. It only lasted for 250,000+ cycles. :wtf:
