Hey y'all -
Having a minor issue with my faithful NR83a and hoping someone might be able to help. Been framing a roof and on Friday I noticed that it's leaking a small amount of oil out of the exhaust cover. Not a ton but enough that the hex bolts holding the exhaust cover on are wet.
Most troubleshooting info online has to do with air leaks but I'm trying to figure out what parts I might need to stop an oil leak. Definitely seems like the large gasket under the exhaust cover should be replaced but I'm not sure what else. Hoping to not have to go through and replace every o-ring in the nailer.
Let me know if you've had a similar issue and were able to fix it.
Thanks!
Thanks!
