Skipper_52
- Joined
- Sep 22, 2022
- Messages
- 2
I bought this unit new in about 2004 and had (2) issues over time. The igniter element gone bad and had to replace the board. The board is an older type without led lights for error codes. I just replaced both of them again but can't get the flue fan to turn on.
Flue fan operates when jumped.
Gas valve has solid green.
Vacuum switch tested good.
Thermostat operates fine.
Main blower fan turns on without gas igniting and will run for about 10 minutes or so with no heat.
When operating correctly the following should happen.
1. Flue fan turns on.
2. Igniter gets red.
3. Gas valve opens and ignites gas.
4. Main blower fan turns on until temperature reached.
My gut feeling is it's the gas valve although it shows solid green. Can anyone help?
