I am finishing off an under-hood wiring harness on my Jag hotrod and I need to run a carbon film resistor "inline" on one of the wires inside the harness loom. In other words, I have to splice in a carbon film resistor in one of my wires under the hood of my hotrod. (picture of carbon film resistor below)
The catch is, I don't want to just solder it in and put some heat shrink tubing over it. I think I should make something a little more durable.
My best idea so far is to solder the resistor onto the wires, cover the resistor and the wires with hot glue, and then slide a piece of heat-shrink tubing over the glue-covered resistor and shrink it down. My concern is that 1) the hot glue might get soft when the under-hood temperatures start to go up, and 2) when I hit the heat-shrink tubing with a heat gun to shrink it, all of the glue is going to run out.
Any suggestions?
Any suggestions?
