How do you tell when an epoxy floor has cured?
bmwpower
Other than waiting the recommmended time period (which is dependent on temperature, humidity, film thickness, etc), what's the best way to tell when the epoxy floor is fully cured?
RonBou
Farmington, CT
Find a hidden corner and scratch it with a screwdriver...OR...just wait the required time and be sure of it. I planned mine around a weeks vacation so I would not be tempted to start moving stuff in too soon.
bmwpower
If you scratch it with a screwdriver, what should happen? It shouldn't scratch?
I'm going to definitely wait the alotted time, I just want to be sure because of film thickness differences (I put on 4 coats) that the floor is ready to use.
Luckydevil
Tampa
Take something with a sharp point and see if you can poke through the epoxy with it.
RonBou
Farmington, CT
It should leave a LIGHT scratch mark and NOT lift the epoxy. With 4 coats I still would be a might careful when bringing in equipment in the beginning. eg; don't drag anything heavy accross the floor if you can help it.
Roadster
Chicagoland
Hell, my epoxy floor has been cured for 2 years, and I still abide by that rule!
If you drag heavy steel with sharp edges across epoxy, it will scratch, regardless of how long it has cured. We're talking about epoxy here, not corundum (9 on Mohs scale of hardness) or diamond (10 on Mohs scale). Epoxy's primary benefit is easy clean-up (e.g., oil & chemicals), not hardness or resistance to scratches.
