Charles (in GA)
Had lunch in a local Moe's Southwest Grill. They have the typical, no ceiling, open to the roof sheet, structure exposed, ducts and conduit exposed, setup, all painted flat black.
Well, I started looking at the ceiling fans............. Tell me this is code somewhere........ anywhere............... NOT!!!!
4 in square box mounted to the bar joist, flat 4" cover plate with center knockout, 1/2 set screw type conduit fitting screwed in the knockout, about 3 ft of EMT to another 1/2 set screw conduit fitting screwed into an octagon box, to which the fan mount and ball socket is attached, then a 6" downrod to the fan.
If you look close at the 4" cover plate and set screw conduit fitting, there is a shiny spot where the fitting has loosened and walked in the knockout hole after the flat black paint was sprayed.
Charles
Charles
