How to Attach Reamer to Drill?
bulletpruf
San Antonio
When reaming out automotive valve guides and using a piloted reamer in a hand drill, I have seen a flexible joint used to attach the reamer to the drill, allowing for straight holes even if the drill is not 100% aligned.
What would this joint/chuck be called? My Google-fu is weak today.
Thanks
Scott
dnschmidt
Phoenix, AZ
See what Goodson has. Call them up and ask them where to get one of these joints. I know exactly what you're talking about but can't find it either. The one shown in the picture above is super light duty for driving screws the one you're talking about looks like a universal joint and is ten times bigger. Sunnen might make these.
bulletpruf
San Antonio
E mailed Goodson. They said they didn’t have it. May have to follow up with a phone call.
Steve_P
I have done this by hand, or with the reamer chucked directly in the drill. If you are using a hand drill, I don't see what real purpose a flexible joint would serve- you shouldn't need a death grip on the drill.
Steve_P
OP, you may need to use two sizes of reamers. I looked at what reamers I have, and I used two different ones, sized .001" apart. I probably ran the first one thru with a drill and the second by hand. No idea, it's been so long.
bulletpruf
San Antonio
I only needed to enlarge the valve guides by about .001" so I only got one reamer.
Thanks
dnschmidt
Phoenix, AZ
The tool he is looking for does exist. There is a YouTube channel called Jim's Automotive Machine Shop and he uses this exact tool and a DeWalt drill all the time for this purpose. It is what it's designed for. He just wants to know where to buy one. THIS IS HIS QUESTION. I don't think he cares what you, me or anybody else would do or think. Me, I'd call Jim's Machine shop and ask him where he bought it. The worst that could happen is they tell him to **** off.
bulletpruf
San Antonio
It's similar to what they're using at 1:38 in this video, but that's a hone, not a reamer.
bulletpruf
San Antonio
Here's something that appears to be designed for this task - speed reducer, some swivel action, fits the reamer square shaft.
ez-duzit
Marina del Rey
leadfoot70
1/4 inch socket drive extension with the male end cut off. Grind about half the depth off the female end. This will give the reamer some side to side play so you don’t bind it if your drill angle isn’t perfect. Chuck up in standard hand drill. Use either a low speed or variable speed with just enough trigger to get you to the slow speed you want. Allow the reamer to pass completely thru and drop onto a padded area below the guide. I use a rubber mat. Total cost to me, single 1/4 inch socket extension and about 5 min in front of the bench grinder.
Go slow
Low pressure as you ream.
Personally I ream to .001
Then I hone the last thou with a sunnen honall
Using a sunnen guide gage I can check my sizes. The reamer is consistent and strait so long as I was careful to keep all side pressure off it by holding the drill reasonably strait. In fact
I have to intentionally force the reamer out of alignment to measure any amount of out of round or out of strait in the guide. And even then it’s so small it honed out easily. I just tried.
Wrench97
Southeastern Pa
What size is the square end?
I have a 7/16, 1/2" drive impact swivel socket that has a 7/16 allen held in by a roll pin that came in a Kent Moore kit years ago to enlarge the head bolt holes in 8.2L Detroits from 14 mm to 16 mm.
The ream and taps were all designed to run through a bolt on guide and be powered by a 1/2" hand drill
The hex goes in the drill and the 1/2" square end goes over the tap or ream.
