how to remove subfloor adheisive
stealman
What should I use to remove pl400 subfloor adheisive from my concrete floor before acid staining?
Warrenator
Newberg, OR
I did a small room with acetone, let it sit and soften, scrape with a putty knife. Didn't work very well in that you could see the residue but got it flat enough to lay tile. Fumes weren't too bad but I did need a fan.
stealman
I want to remove the residue so the acid will stain it. I want to clean it tomorrow and get the ceaner today. Does anyone know what will do this?
pop pop
Virginia
The one and only time I did this took a week. They sell a scraper at HD. Looks like a garden hoe, but straight. I'd loan you mine. Only used one time.
930dreamer
Amarillo,TX and Stinnett,TX
pop pop has the right idea, I removed carpet on concrete and stained. The scrapper uses a 4" straight blade that's replaceable. I rented an industrial buffer and used the green/black pads after that.
