HVAC suggestions
mpraddict
Central Ohio
Here's my dilemma. I'm at the point in my garage build where I need to make a decision about HVAC. The building footprint is 30'x60', and the space will be divided basically in half. One side shop and the other car parking/storage. I'm looking at horizontal residential LP split systems. Problem is I'm concerned about both sides sharing the same system with the protential of debris/dust/paint created in the shop side migrating over to the storage side. Seems a bit excessive (and costly) to install two complete systems for realtively small spaces. I've looked at the electric mini units, and I'm not sure about them.
Looking for ideas.....anyone?
rickairmedic
louisville ,Ky
I would suggest if your looking at LP go Hybrid heat with a heat pump and an LP furnace . I would also suggest if your going to heat and cool both sides off the same system use good quality filters in the system and possibly add a second filter inline where the supply ducts go over to the clean side of the shop. You will spend roughly $500 to $600 more initially on Hybrid but it will pay you back in quick order especially if you are running LP.
Rick
mpraddict
Central Ohio
So with a single system, will I be able to adequately filter the dust/fumes/paint in the air that will be generated on the shop side and keep it from migrating to the display/parking side? Are there other options I'm overlooking?
rickairmedic
louisville ,Ky
almost anything can be filtered out but the more elaborate the filter system the higher the cost with 2 30X30 areas you may want to look into mini ductless split systems for each side .I heat my garage which is roughly the size of one side of yours with a tanktop heater and am quite comfy in the winter wityh a standard uninsulated garage door .I will admit though I dont heat it 24/7 only if I am going to be out there playing do I heat it .
Rick
