Mister B
Last weekend when I went to jack up my truck with an old 2 1/4 Ton hydraulic floor jack that I have, it pumped and raised the jack up ok (not great) with no weight on it, but once the jack gets to a certain height (still with no weight on it), I could only pump the jack up when the handle was almost all the way down to the ground with maybe 2 to 3 inches of travel left on the handle. That last 2 to 3 inches of travel was the only point that it had any pressure to lift the jack and it barely lifted at all, at that point.
I thought that maybe it could be low on oil, so I wiped some grease off of the jack and looked around and found what i thought could be the oil plug for adding oil. There were 2 flat head screw in plugs on the rear of the jack behind the base of the handle. One small and one large. The small threaded plug on the right had a sticker beside it saying caution do not adjust valve (or something to that effect). So I started to unscrew the larger threaded plug on the left, and once I started to unscrew it, oil immediately started coming out from around the threads, so I screwed it back in. If this is the correct oil fill plug, I guess the oil must be full?
Here is a picture of a jack similar to mine that I found online that most closely resembles the location of the plugs on my jack. Just like mine, the one to the right of the gear is smaller and the one to the left of the gear is larger.
Can anyone verify for me that I found the correct oil fill hole on my jack?
If that is indeed the correct refill hole, my jack seems to be full unless I did something wrong. I had the jack in the down position when I started to unscrew that plug.
Any other ideas what the problem with my jack could be .
Any help would be appreciated. Thanks.
