hydraulic press
landrover bodger
norfolk england
I am looking at getting a press for home use . it will mostly be used for bushes and bearings . the question is will a 12 tonne be power full enough . it will be an ebay china one . I can get one for £85 about $125
fnieto
Tucson,Arizona
If you can get the 20T then get it. They seem lightly built coming from China.
I have a HF 20T and it does plenty of bearings and races as well as bushings.
During assembly, I discarded the hardware and used grade 5 on all connections (individual).
Instead of four long bolts for the top connection, I used eight individual bolts washers lock washers and nuts. Much more sturdy and a good improvement to the light weight construction.
Moose-LandTran
The Brink of Insanity (England)
I have a little Sealey 10t one like this: http://www.ebay.co.uk/itm/SEALEY-YK...278732?hash=item41a3d1530c:g:7RwAAOSwJb9WqfMz
It's actually pretty good, and it's done everything i've needed it for; wheel bearings, ball joints, bushes, just any general pressing job. It's not the best press out there but it's hard to beat for the money. It's also small enough that it can be put in the car easily, as i've used it for doing wheel bearings on site.
volaredon
IL
I got mine from Craigslist, US made 15Ton Dayton from Grainger, older model.
toplessHO
central florida
the old rule of thumb on presses was that for every ton multiply by 10 lbs
this is not including a jack.
so a 10 ton is at least 100lbs and 20 ton 200 lbs
this doesnt make up for poor design but gives you an idea that if its a 20 ton and weighs only 100 lbs I would walk away
volaredon
IL
Moose, what is that symbol called in front of your dollar amounts? Have seen it before buy dont know what it is, I assume you're not in the US or Canada? I'm much more familiar with seeing $$$
owenst7
Anchorage/Reno
There's nothing wrong with the HF 20 ton press now that they got rid of the cast arbor plates. I've rebuilt dozens of 1 ton axle carriers with mine. I've used the hell out of my SWAG press brake too.
I'd like a bigger 50 ton press for doing full width semi float wheel bearings (although I've done a few dana 60s with my 20T), but I would still keep this one around for quick setup and portability.
I don't feel a 12 ton would be very useful for automotive work considering it takes up just as much floor space as a 20T and doesn't cost significantly less.
Moose-LandTran
That's the pound sign, for Pound Sterling, British currency.
Doesn't Europe get the same Chinese imports just under a different vendor label?
Some of it, yes, not all and not all at the same price.
North Run Grader
Swan Hills, Alberta
I appreciate the fact his location is in his profile, so £85 would be British Pound, he was even kind enough to provide the conversion for us. When you compare the floor space consumed by either, personally I would go with the 20 ton press. With a quick Google search you can find all sorts of improvements, but with the larger capacity you shouldn't be regretting the purchase. I have a 20 ton from my father's old shop currently stored at my uncle's, I just don't have the room until I finish my garage renovation.
