coreyschaff13
- Joined
- Feb 14, 2013
- Messages
- 6
I am currently in the process of building a house with floor heat in the garage. I have been browsing this site for the last couple months trying to gather as much info as possible.
I am located in North Dakota, 1120 sq. ft. attached garage (3, 9' overhead doors, 2 walk in doors, and 2 3'x4' windows). 10' walls, 2x4 contrustion w/3.5" FF insulation. 16" insulation in ceiling.
Using 4 loops of 1/2" pex, 12" centers. Loops will be 250'-260' in length. Plan is to keep the garage at around 45-50 degree for most of the winter, with the occasional rise to 60-65.
The heat loss calc I had done suggested that I would have a heat loss of 43,000 BTU's at 65 degrees.
My plan was to use 2” XPS insulation underneath the slab and around the top 2 feet of stem wall/footing. My builder is trying to convince me to not insulate the wall between the house and garage for the fact that it is going to be warm on the other side. He also does not want me to go to the top of the slab with the 2” XPS. Instead he wants me to use 2 “ along the wall up to the bottom of the slab, and then between the slab and wall he wants to use a ¾” expansion joint as a thermal break.
All of the research I’ve done is to use 2” XPS all the way around the slab and walls.
The builder put a knock out 2x6 into the wall forms for the garage so that the top 6" of the garage wall will only be 4" wide (3.5 2x4 with 1/2 Sheetrock)so that the framed wall and concrete wall are flush. If I put 2" XPS all the way to the top of the concrete wall, then I will have a 2 inch lip where the concrete ends and the framed wall starts. My concern with doing it this way, although I think this would be the most efficient, is how does a guy go about finishing the wall so that its flush?
I want to tin the bottom 4-6 ft of the walls for washdown purposes.
My orignal thoughts were to have him frame out the garage with 2x6's instead, and he said he could do that, but he thinks its a waste of money. According to him, almost all garages around here are 2x4 construction. Money is an issue (of course) but I dont think that the 2x6 construction would be a waste.
I was wondering what your guys' thoughts on this would be.
P.S. sorry for the lengthy post, but I hope I explained this well enough.
