Inexpensive 2 stage transmission jack
pbon
Vevor is a decent Chinese brand. The $155 price is cheap in my opinion. I paid more than twice as much for a Derek Weaver 2 stage trans jack a few years ago and that was the cheapest one I found. No idea about shipping — maybe that ruins this deal.
vwpieces
Hills, PA
If returns are anything like Aliexpress you'd be better off buying from Amazon for $152.99.
OOPS. The link is the same one 67in. I looked earlier and did not get that same listing. I have been in the market for one and all have been over $200.
That one is a lower height. The New version available on Amazon is $210, same height as Vevor site.
bubinga
i'd like to have one of those things, :( :( but can't justify the $$$$$ for as little as I would use it though :(
xjfish
Is VEVOR.com legit? I have seen tons of ads with "VEVOR" in title lately; some have been obvious spam/scam. 67" isn't very tall for a 2 stage, but price is right?
XXL__
Yes, legit company. This is their website.
Name:
Qihua Zheng
Organization:
Shanghai Sishun E-COMMERCE Co., Ltd.
Street:
5th Floor, Building 6, Lane 958, Jinsha Jiangxi Road,
Jiading District
City: Shanghai
State: Shanghai
Postal Code: 201824
Country: CN
Phone: +86.16601839140
Email: 505cae3cc63eb62668fb2b5b39f17000b56545dc.png @ vevor.net
They have been 'spreading it around' banner ads, social media, etc., for a couple of years now, trying to build their brand. I bought a large hammer drill and a concrete saw for a one-off project a couple of years ago. No complaints.
consti2tion
East Texas
I bought a PCB for a mini split on aliexpress that ended up not being the correct one, the return process was not bad. Got a full refund and they paid for return shipping.
finn
The UP, God's country
I have a couple of things from Vevor . Does the job, considering the price especially. It’s generic Asian import, same as HF and dozens of other resellers, including Jegs and Summit
Farmall450
Marengo, Illinois
Just don't stand under it. My Vevor barrel dolly showed up Friday - the bearings had 4 different shields/seals (that I could see, including the 1 missing anything), 1 of the nuts had no thread, and the handle was welded about 30 degrees off of vertical.
Shortbuscandid8
I have that jack and it has worked well. My only complaint is no foot lever to lower it. You twist a rod that's only a couple feet off the ground. Makes for some interesting situations when working alone.
rust in the eye
Chicagoland
I have just received and assembled one of these so wanted to share my thoughts about it.
This was bought after seller's remorse having sold my very nice, albeit quite large and seldom used, professional grade trans jack.
I bought the similar one now being sold at $166 by Amazon. Its rated a bit higher @ 1322# and looks identical to the one posted, probably is identical.
If you want adjustment in more than one plane buy something else.
The saddle angle adjusts on only ONE axis, less than ideal. The second adjustment screw is merely a crude side to side adjustment which can be accomplished by moving the jack so redundant, NO tilt capability in second axis. The entire saddle assembly is a bit sloppy though so a bit of lateral tilt is possible, although not intended.
