Rigmaster
Picked up a 2nd gen NEST thermostat and was looking at install instructions to install it in my house. I currently have an electric heat pump, apparently with a Dehumidifier. NEST help chat says I need to hire a NEST Pro installer since I have a dehumidifier, but I am confident enough in my abilities that with a little guidance, I can do this myself without causing any damage.
Seems like the big deal is that if your Dehumidifier is a two wire, you need to install a relay, but if it's one wire, you can simply install the "Dehum" wire from the old thermostat on to the "*" terminal on the Nest.
I have not yet gone to the actual HVAC unit to see if it looks like a one wire or two wire dehumidifier, just trying to see if anyone else has been thru this before, and can provide some peace of mind that this is not that complicated, and I should be OK doing it myself, or not.
Thanks!
Rig
ps- the existing thermostat has the following terminals (only listing those with wires attached, and the wire color to the right of the terminal label):
W/W1- White
Y/Y2- Yellow
G- Green
R- Red
Y1/W2- Black
O/W2- Orange
S2- Brown
S1- Brown
DHum- Purple
C- Blue
Thanks!
Rig
W/W1- White
Y/Y2- Yellow
G- Green
R- Red
Y1/W2- Black
O/W2- Orange
S2- Brown
S1- Brown
DHum- Purple
C- Blue
