Insulating a Metal Garage
ncgarage
North Carolina
Hello everyone.
I am in the process of building a 40x52 metal garage from Alans Factory Outlet. I have been doing alot of research on the insulating of the building(diy options). In my opinion it seems that one of the optimal solutions might be to take one of the diy spray foam kits and do all the crevices and come back with either foam board or fiberglass insulation? I'm in central North Carolina and I only plan on heating and cooling sporadically so I do not need "super insulation". It doesn't seem like very many people have done this? Any thoughts?
StefanNH
I’m using fiber glass rolls in mine. When I finish it I may put a layer of rigid insulation behind the walls.
gimpyrobb
Cincinnati
I have a 30x40 metal building. If you really want it insulated, its kinda a PITA. I put 2 inch thick foam against the sheet metal to fill in-between the metal structural tubes. Then I put up 2x4 framing to use fiberglass batt insulation. If I just put the foam up, the tubes would be uninsulated.
charlie101
I have an 18x45 from Alan's and did spray foam (not DIY) with 2.5" on the walls and 3" on the ceiling. I covered the walls with OSB and have been happy with it.
