Insulating Florida detached garage
mhand75
Good morning,
Gotten a lot of great information from these forums over the years, but this is my first time posting. I moved into a house earlier this year that has a detached garage that I use as a woodworking shop. The shop has a Mr. Slim. mini-split, but it is not able to keep up in the summer. Temperature in the shop frequently got up to 95-99 this past summer.
I've had mini splits in two previous Florida garages before with little insulation and they've worked great. Those garages had a drywall ceiling with uninsulated attic above and uninsulated outer walls.
I'm not sure what best approach is for insulating the garage. I would like to keep the ceiling open.. it is only 7 1/2 feet hight and I'd like to run my dust collection piping in the rafters.
The options I was looking into:
  1. Radiant barrier - would put the radiant barrier over the rafters. With the 2x4, this would give me a 3 1/2 gap.
  2. Put batts between the rafters.
I was thinking the batts would be best, but I'm not sure what I would put over them after stapling them in place. Could I cover with OSB or something similar?
Open to any other ideas?
Also, there is no roof vent, but there are soffit vents, which seems odd? If I go radiant barrier, would I just close off the soffit vents? If I do batts, I'll put in a roof vent.
Details:
20x30 detached garage used as wood work Concrete walls
Asphalt shingle roof
Soffit vents
No roof vent
Mini split AC
Thanks for any advice.
Marcus
My Old Tools
Hamrick Lake, TX
My experience in Texas should be similar. Most of your heat gain is through the roof. 4 inch bats will help, but I went to 4" plus 8" in my latest shop and it really made a difference. The other option is spray foam of course.
