If the insulation is exposed - be sure to use the fire rated product. Standard Kraft facing is flammable and required to be covered - typically by drywall.Staple up kraft faced batts to the rafter ties
The OP is in Mississippi. I suspect poly VB in his climate may be undesirable.In my climate, poly VB on the bottoms of the joists to keep your heated air inside. R30-40 between the joists.
The cheapskates like to use grow-op poly here because one side is white and brightens up the space.
No. No heat either except maybe a space heater. Doesn't get all that cold for that long here. It does get hot though...Are you air conditioning the space?
The ceiling as in the bottoms of the rafter ties or are you looking to keep the space between the rafters and ties open?Yes wanting to leave the ceiling exposed. Will be working on restoring a truck so would be welding etc.
I would not do unfaced fiberglass without covering it because I would see myself in a constant light dusting of fiberglass.I think without ac, you'd be fine with unfaces batts between the rafters. May need some wire or insulation props.
Should keep the heat down some and I don't think there's any surface that will condense.
