Is there a thread for budget builds?
Ceezer
SC Midlands
Where are the buildups from guys like me? The meager state employee who has been separated for more than a year, father to a 10 year old daughter that expects all excess funding (Hah!) be routed in her direction, that was able to turn his attached 2-car garage into something desirable and inviting?
Don't get me wrong, living vicariously through most of these builds has been a wild walk through fantasy, but then I start to get that sick feeling in the pit of my stomach as I know I'll never reach such levels.
I know there's the 2-car garage thread, but even some of those are high-end and probably unobtainable. I'm just looking for some "Joe Plumber" type garages...
lupinsea
Setting up a cool space doesn't have to be costly. It's all in the execution. Being deliberate in the design and layout and the details helps a lot. And keeping the space neat and tidy and well organized will also help.
But if you're looking to make your mark? Some ideas:
Paint
It's relatively cheap and easy way to brighten a place or change colors. Want a stripe around the room in an accent color, get a pint of pain for $15 or so and a $5 roll of paint.
Heck, even if you don't have sheetrock on the walls and just have open stud bays that would be fine, too. That would actually look pretty cool, with painted studs and sheathing. The way the light would hit that would give a good depth and pattern to the wall.
1/2 Wall Covering
Or, instead of wall boarding up the whole wall, do part of it. Maybe the lower 3 ft up to work bench height. Nail blocking between the studs at a given height, then nail a 1x2 across the face of the studs and have the wall panel **** into the bottom of the 1x2. Open studs above, smoother wall surface below. See comment about painting studs above. It cuts sheetrocking efforts and material costs by a bit more than half and effort by about half, too. and it's an easy project to tackle by one's self. Nail up some batten strips over the panel joints if you don't want to mud and tap.
Anyways, I've love to see how everone else comes up with more budget minded garage projects, too.
Being able to DIY
If you can do the work yourself it's a big savings on labor, too.
I've posted these pics here before but I'll do it again. This was a garage organization project I did at my place. It's a very narrow garage. Total cost to sheath the wall in peg board + the micro-work bench built-in cabinetry I did was probably $400 and that included the trick anchored pegboard hooks. The whole thing was built with a skill saw on some saw horses. Doing it again I would have stepped up to a Birch shop grade plywood that would have been $10 more per sheet than the ACX that I used. It would have added $20 to the project cost. But oh well, it's done now.
What I started with.
Sheathing the wall in peg board.
Starting to put up "stuff" on the peg boards. Note how the various elements line up and register off of the garage structure. There's a 1/2" reveal joint between the concrete foundation and the peg board. This line is carried into a rabbeted reveal joint between the wood base of the cabinet and the cabinet box. The joint between the upper and lower peg board panels lines up with the counter top.
How everything got laid out on the wall. The top shelf stopped about 4 ft short of the end wall. I extened it mostly just to carry the visual line of the shelf from wall to wall but it also helped with a few extra fee of shelf space.
fflintstone
MOFnowhere Mi.
at least you have a job.
About 3 ½ months before I short sold my house and lost my garage, I did a HUGE cleaning of it. I organized everything. I started moving the seldom-used stuff out. I had space to work. I was much more productive doing my side jobs and getting projects done before I ran out of time and had to move.
Cleaning, storage, organization, light colored paint, and good lighting are the basics for a garage make over.
My budget is non-existent. I have to build a shop in my new location. My entire savings will go into 20 yards of concrete for a floor. I will have enough left over for a load center and service wire to the barn. The $800 for 20 fluorescent lights will have to be one at a time.
zer01
I got all my lighting on craigslist. Look around and find deals on used stuff. Most of my garage storage, lighting has been found through craigslist and yard sales. Don't let the size and expense of some of the garages on here give you a complex about your income or own garage. There are more people using this site that have functional garages that have no color coordination than those who can buy all the fancy organization stuff. Take your time and use your money wisely, $800 for lights could stock a whole garage for budget minded people.
fflintstone
MOFnowhere Mi.
When I lived in Oakland co. I bought and sold on CL all the time. Now that I live in the sticks it is far less of a resource. Although I check restore and garage sales for lighting fixtures it is really false economy to put in old T12 fixtures. The newer T8 fixtures offer more lumens per watt and save money over the long haul.
Dan in Pasadena
Pasadena, CA
Basic stud space storage will help you when you're low on funds. See first picture.
I've posted pic's of GJ member Nimrod's garage. Do a search on his name, there are more. To me, it's the ultimate example of a no frills but still AWESOME garage. Of course it would probably take you years to duplicate a lot of his equipment but at least it will give you a goal to shoot for. Make sure you post pictures of what you do. Not everyone here as unlimited funds (me!)
Craigslist is your friend. Use the Materials section for cheap lumber. General section for cabinets. Personally I followed Jack Olsen's (do a search) idea to re-purpose everything possible to minimize expense. I gathered ALL my unused & left over paints: Everything in white & off white, flat, semi gloss, etc I mixed together to paint my garage. Other paints I mixed together to make a medium gray, and finally all the remaining I mixed to get a 3rd color. Mine came out yellow and I am using it for cabinets, etc.
Simple Stud Space Storage
Nimrod's Garage
My Unused/Leftover Paint Stack
What I did with that Paint (Sorry, crappy cell pic's)
P.S. Pardon my mess, my garage is much better now but I have no recent pictures.
type550
Melbourne Australia
My whole build is totally on a very tight budget - hopefully less than $2k. A lot is going into about 20 litres of quality paint, but virtually everything else is recycling and reconfiguring what I have and cleaning/painting them up, heaps of bargains off ebay - you just need to know when to buy and when not to - if you miss out, something very similar or better will be there again in a couple of days. Also it is all in the planning - so many things I wanted to do would have cost me a heap, but thinking and planning I have come up with better solutions - a lot of it found right here on this site. If you have basic handyman skills, build everything yourself - yes you make a lot of mistakes, but you learn very quickly! Finally is doing deals - in my business I do graphic design - a guy I know who sells lifts and other items has bought a stand at an upcoming car show. I will design a banner and a flyer for him and in return I will get racedeck flooring from him to do my garage - win, win (pity I don't have the height for a lift!). I believe a good garage is in the presentation with a space for everything. Mine is only a one car garage, so I have to use my space wisely so I have a practical work space.
Buck
I'm right there with you. I did my build myself. I purchased lumber on sale and used my military discount whenever I could. I buy paint from the mis-matched section that has been heavily discounted as long as its something I can use. I perform my own labor in most every case. I've made a few mistakes but nothing permanant. Most guys on here are on a budget so dont think that you cant have a garage unless you are some kind of baller. I saved, waited, planned and saved more untill I could start on mine. Its in the dry now and I am finishing it 1 paycheck at a time. I've found that $200 a month of disposable income towards the garage will buy enough material to keep me busy for most of that month. Between my deployments and work, family life etc its taken me 2 years to get to the point I am now on my 2 car garage build.
rickycobra
Even with a budget build you can still get the pro look just takes longer to get the money. Shopping through craigslist will allow you to barter and find things cheaper even. You can even spend time refurbishing old run down things.
