Is this safe ?
Garage5.9
Maui,Hawaii
Blew a fuse and needed to get some work done. so i ask do you think this safe for a temp fix ?
HoseB
Do you really have to ask or are you just trying to get a reaction?
east_tn_emc
East Tennessee
Not sure if you will be able to get the screwdriver replaced under warranty at Sears when it melts....you might have to go to K-Mart to get it replaced!
nehog
Jaffrey, NH
What is the other fuse rated at? That's a 70 Amp screwdriver, I believe.
(I seriously tested, in a lab, stuff like that to see how much current they could handle... you can light that screwdriver up like a light bulb with good enough connections!)
crewchief888
NW indiana
i think the CM "fuse" is a better alternative than the remington / winchester model.
i'm thinking a .223 may be a little too small,
30/06 should be 'jus 'bout right. :yikes:
:beer:
klhitman
pewee valley
if you have to ask then its a NO. i have went in service call to AC unit that have had copper pipe instead of fuses. and the folks would ask why i charged them for fuses, " but it has work for so many years why didn't you just leave it". hummmm i wonder
G
Garage5.9
Maui,Hawaii
I wasn't serious when i asked about that pic. like i said i found it on the net , im no electrician but even i know that wouldn't be safe
