I have used JB Weld twice:
Once on the motor mounts of a lawn edger who's engine bolts used to work loose and fall out all the time. I filled the threaded mounts with JB Weld, drilled them out, and tapped them. After 48 hours I reinstalled the mounting bolts and torqued them to spec. This repair has lasted two years of frequent use and I've never had to retighten the bolts. An inexpensive repair and a sucess.
More recently, I nicked a PVC irrigation line while tilling: this nick later resulted in a bad leak. The nick was located right in the middle of a T-fitting and would have required a new T-fitting, three inline couplers, and six cuts to the three irrigation lines connected to this T-fitting, not to mention digging up a major part of of a freshly planted garden. So I decided to try some JB Weld to repair the nick. I sanded the PVC T-fitting with 80 grit paper, and then applied about an 1/8" layer of JB Weld over the nick and surrounding area. After 48 hours, I tested the irrigation circuit... it held (at 65 PSI water pressure) and the repair took less than 5 minutes to accomplish. I think I can call this another sucess, at least in the near term. Will have to wait and see how the repair holds up over the next 5-10 years.
