"Jelly Jar" replacement
JordanOH
OH
Looking for an LED replacement for a 'jelly jar' style light. I installed some in a feed mill several years ago, these had to be dustproof. Need a couple more but supplier says not available. These are going in an oven hood, must be pressure washer rated. Thanks for any help.
cybrdyke
USA
hoodmart.com or hoodfilters.com
The glass globe should be tempered glass, gaskets should be silicone and bulb should be a higher than normal temp.
Good luck,
CD
Stuart in MN
Minneapolis
All the major players (Crouse-Hinds, Lithonia, RAB, etc.) sell jelly jar style LED fixtures these days, but you probably won't find them any cheaper than the one from E-conolight. Note there are other styles of LED vapor tight fixtures available that aren't the jelly jar style, in case that's an option for you. Here's the section of the Greybar Electric catalog for vapor tight fixtures: https://www.graybar.com/lighting/in...s/vapor-proof-fixtures/c/vapor-proof-fixtures
