Joint filler question
S0schaef
Denver
I am filling my control joints before my polyurea coating and have a question. I have already filled the joints with a 100% epoxy joint filler however the joints are still visible. Now that the joint filler is completely cured is it ok to add another layer of joint filler on top in order to smooth out the voids a little better?
Garage Flooring
Grand Junction, CO
Yes, but make sure the previous filler is at least sanded and then wiped clean so the two can bond, mechanically.
Yes sand it first like Scotty said and do not use any water. Clean dust with solvent.
bikerneil
Carlsbad
Specifically which filler did you use?
How did the process go - was it straight forward? I want to do the same for my expansion joints. Any tips are appreciated!
Shea
California
Most of the vendors sell the appropriate materials to fill the joints. The key to successful joint filling is to make sure they are complete full (no depressions) and then grind the joints afterwards to create a nice flush surface. When that is done, it's very difficult to tell you had joints in the concrete to begin with.
bikerneil
Carlsbad
Thank you Shea - so, the process would be:
1. Grind entire floor with floor grinder.
2. Fill expansion joints & ensure they are completely filled to level of the rest of the floor.
3. Hand grind top surface to ensure nice flush surface.
Is that correct? (I'm doing mine soon...)
Shea
California
Yes, you have the process correct. I would actually fill and grind first and then grind the entire floor as it will provide the same surface profile throughout the entire slab, but the order is not that big of a deal.
Armorpoxy
Agree with all above. Tip...to prevent sagging of joint fillers always use either foam backer rod in the joint or sand to act as a support for the filler otherwise it will run deep into the joints at times.
