MeentSS02
I want to install a few new circuits in my attached three car garage w/ attic access and finished walls (sheet rock). Currently, the only outlets available are on one circuit, and that circuit is a 15 amp circuit, most of which is fed by 14-2 wire. Needless to say, it isn't sufficient even for what little I will end up doing in there (car detailing, basic maintenance, etc).
My current plan is to do a few different circuits so I can power a few things at the same time (think lights + a buffer, grinder, etc) without worrying about overloading a single circuit, but I'd like to be able to expand the circuit if I so desire. In my search of the vast interwebs, I came across a site that said that the first thing in a circuit after the connection to the service panel could not be a junction box, but I'm unsure why they said that?
I wanted to run 12-2 wire for at least one or two circuits in the six I have planned from the service panel straight into a junction box, and from there to my planned outlet(s). I know I'm making this more difficult than it needs to be, but I will probably add additional outlets once I do some work in there and figure out where else I need power, and I would rather expand the circuit from an easy to access junction box in the attic than try to fish a wire to the installed outlet.
So is a service panel -> junction box -> outlet permissible? Or should I rework this plan before I go any further?
