Just Started One Myself
z28toz06
Connecticut
Began building a week ago last monday. Had the framing and sheathing done in 5 days. Basically me and my friend. With a couple of guys thrown in here and there. Hired a crane to place the trusses.
Start shingling the roof this weekend.
Craig Balzer
Colorado Springs
z28toz06inConn
Nice Place and it surely is going up quickly.
I'm guessing 24' by 30' with 11' walls????? Plans for a lift? What's going to be stored/worked on inside?
Craig
DynoDave
Nice progress. That's going to be a great space when you're done. How do you plan on using the upstairs?
NSXSOON
Florida Space Coast
Looks great! I bet you had a buch of cold finger days doing that framing and sheating and maybe a few more to go to do the roof! you sure are moving fast though. I can picture the lift in there already!
Z
z28toz06
Connecticut
ChucksCrib said:
Based on the snow accumilation...............I'm gonna guess that your somewhere in Litchfield County
Yes sir SHaronto be exact. It snowed on us all day tuesday which was day 2 of the project. Mother nature kicked our butts that day! It was a wet clingy snow and it just wouldnt stop. We finally gave up about 1 pm so we lost 1/2 a day really. Not bad for 2 guys.
Z
z28toz06
Connecticut
Chuck from Salem? I was hanging out with you at the Gentlemans club a couple of weeks ago! How the hell are you? I am Tom with the '03 Black Z06.
Z
z28toz06
Connecticut
Craig Balzer said:
z28toz06inConn
Craig
24 X 32 actually. 10"8' walls plus another 5.5 feet in vaulted ceiling just in case I want to work on a double decker bus or something!
I'm sure I'll be working on the Z, plus my son is into cars and he's always building and blowing something up. I'm designing radiant heat for the floor. It's a closed system, I'll use a hot water heater for a heat source.
Z
z28toz06
Connecticut
That's going to be a loft. I will keep all my OEM equipment from the Z when I do mods to it!
Z
z28toz06
Connecticut
Got The Roof Shingled
Here's some action photos of the roof shingled. Hopefully typar it and get the windows in on Monday.
:bowdown:
Z
z28toz06
Connecticut
Finally got some windows in!
Finally! Got 3 of the 4 windows in. Lumber yard on delivered 2 of the 3 I ordered. Have to pick up the other one on the way home tomorrow. :rocker:
Snowed like hell on Friday. We were supposed to get 4 to 8 inches. We got 4 plus 8 inches and 2 more on top of that!
Garage door guy is coming the first week of January. :3gears:
cork
Central PA
any idea which water heater you will be using? Im doing the same thing just havent decided if i should spend the money on the Polaris.
Z
z28toz06
Connecticut
The polaris is a large volume unit. Their smallest one is 100,000 btus. Way more than I need.
A buddy on the corvette forum suggested this unit:
Being a Vette owner has its advantages :)
The model is a A.O. Smith BFC-50. (L.P.) propane fired. I would also recommend a TEKMAR hot water reset controller that will vary you water temperature based on the outdoor air temperature. ex. If it is 0 degrees out, you water heater puts out 140 degree water. If it is 40 degrees out, your water heater puts out 110 degree water for futher energy savings.
It has a sealed burner source so it doesnt create spark or have an open flame, which is importatnt if your garage has gas fumes, (and whose doesn't!) or will store flammables. This will prevent the possibility of fire i'm told.
T.
Z
z28toz06
Connecticut
ruby76 said:
What are the plans for the loft area, storage? or work space?
Just storage, for oem parts, lawn furniture in winter etc. It will have a knee wall on the back wall which will allow you to look out of the loft to the rest of the garage. The lift will be down in the back so when I raise the car I should be able to get in the trunk or under the hood if I need to! it will all depend on the length of the car. :3gears:
mdshore348
maryland
wondering if the second attic level floor has enough strength for everyday use, it looks as if its only 2x4 truss joists
bmwpower
Looks to be 2x6 on the bottom to me.
Throttlejockey
CT
T.
Any idea on cost for that unit? I have LP fired Bradford White 50 and it's not very efficient for what I need.
Z
z28toz06
Connecticut
NICE PIC THROTTLE JOCKEY. I don't have a cost yet but I will find out and post. Here are some photo updates:
Placed the french door in the loft today:
Put the last window in the back yesterday:
HERE"S WHAT THE INSIDE IS GOING TO LOOK LIKE WHEN I"M DONE!
Just Kidding, stopped by and saw John at LOMOTION CORVETTE in pleasant Valley/ Wappingers falls in NY Saturday. Shot the $h!T for a while and got a free tshirt. Stop by and say hello, he's a great guy. Lots of pix and stuff. Bruce HArlan was in there in July when they had the big National Corvette Museum display over at Lime Rock. He drove his prototype 06 Z06 in there and took some pictures in the showroom.
Keep the shiny side up fellas!
T.
Z
z28toz06
Connecticut
Ready for the doors!
Ready for garage doors! trimmed out the wondows and the garage door openings today. Finished the hurricane clips and all the truss bracing. Should I wait until the floor is poured before I wire and insulate??
bmwpower
The only reasons I can think of waiting to wire is that (1) if you want a certain height for the outlet boxes. That will depend on the floor height, which technically can change until the floor is poured... Or (2) yo have to run conduit through the slab.
Insulation can be installed at any time, however if you want to keep the slab a little warmer while it drying, insulate first.
You do have to wire BEFORE you insulate though since the inspector will need to see the wires, stapling, etc.
Z
z28toz06
Connecticut
Got The Doors On Finally
Got the doors set. Had to pile some blocks under the doors because the floor isn't poured yet, but at least we'll keep the weather out until the spring.
Blue Seducer
N.O La.
If you are planning for a lift, you might want to put industrial can lights in the floor. They work alot better than a drop light. :beer:
Craig Balzer
Colorado Springs
Racerboy
I did some Internet research on this very subject a few months back. I found this site which seems perfect:
http://www.tahoelighting.com/store2.asp?Category=PavingLightsandInConcreteLighting
About half way down this web page you'll these in-concrete lights are available in an 8-light kit (also 14 lights but that seems way over-kill.). You have the option of three different shapes for the lights: sqaure, rectangular and octogonal.
My plan is to buy the 8-light kit and position them so 4 are in a square or diamond pattern under the front half of my (eventual) 2-post lift. The other four light would be similarly positioned under the rear half of the lift.
The 8-light kit is $262. It comes with everything you need to light the underneath of your car. NOTE: you will need to order what Tahoe calls pre-forms for each lamp you are going to install. The pre-form is a disposable form that you place around each lamp fixture before you pour the floor. The pre-form is then removed from the dried concrete floor leaving a properly sized hole for the finisher pieces of the system.
No affiliation with Tahoe adn I have never used them.
Craig
