I have an Enco Taiwan 12 x 36 bench lathe, 1984 approx. It has been a good machine and has many hours of use. The main belt has given up and I'm struggling to figure out how to get the "Jack-shaft" out in order to replace the belt. This version has the shaft built inside of the main box casting at the back. I have the main spindle and the back-gear out already. The Shaft pivots on a pin "to tension the belt after switching speeds", but I'm not seeing how to get this assembly out of the box. There is a collar with a set-screw that is loose, but the pivot pin still seems to be held by something, and even if I get it loose appears to be too long to get it out of the assembly. Has anyone ever been into one of these?
