Lathe obsession....
Dennis Leigh Henry
South Central, IN USA
On the gear fix, I've seen them commonly welded up (silver soldered or brass brazed or specialty filler material torch welded into place) and then re milling of the gear tooth. And they seem to do well / ok...
macgyver37
Pittsburg, Kansas
I had a 1914 18" SB with 8ft between centers. I found my current big lathe and decided to sell it to a friend that will probably put it back on a lineshaft. Good machine, I mainly wanted it for doing driveshafts. I am down to 3 metal lathes now.
As for the lube, yes it is oil as Fretters said. I learned the hard way a long time ago that not all zerks are for grease. I didn't know for a long time that there are oil zerks, so I got the job of taking things apart and getting the grease out.
I didn't look that close, but I'd put some glass oilers on the headstock if you don't have them already, at the very least put some Gits oil cups on it.
Dennis Leigh Henry
I have a SBL vertical mill, vintage, that has "oil zerks", which I have converted to regular oil cups..
C
Cgantner5150
Metairie, LA
Took the clutch mechanism apart today to see why it wasn't working/gripping. Everything looked good. Took it apart and realized that I had a washer in the wrong place. Figured out where it went and all works well.
I am using 0w-20 oil at the moment. The bearings don't seem to even get warm - even at high speed.
Another video link.
