Layed compressor over, what now?
nonhog
Arizona (Tucson)
I'm a bit concerned that when I drug home a free 80 gallon compressor it may have seeped oil into the cylinders or the tank?
Should I be worried? What steps should I take to make it right?
just see the top of it
OccupantRJ
Eastern North Carolina
Turn it by hand for a bit. If it turns free, check oil level, then turn it on for a short burst several times. If it does ok, drain tank which should be done anyway.
DTE
North Carolina
Stand it back up and run it. That is how I hauled mine home.
mitusa
SW Oklahoma
Might stand it up and let it sit for a while before doing the above.
N
nonhog
Arizona (Tucson)
Thanks guys!
My main concern is oil in the air (or how to avoid that) Its been upright for months. It blew a capacitor and work tossed it. I figure its worth the price of a capacitor to see if its a keeper.
larry_g
oregon
If it has not been run then to be safe you could disconnect the discharge pipe from the pump and allow the pump to blow into free air for a bit and see if it is blowing oil. Once it runs for a bit reconnect and go for pressure.
lg
no neat sig line
fatfillup
Finksburg, Md
I would still turn by hand first. From what i understand, and I am no expert, if the cylinder fills with oil and you power it up, you can bend a connecting rod. A hydraulic lock situation. Turning by hand will not cause damage. I may be mistaken.
corrie
Make sure the oil is full. When I laid mine over to get it home from the store it leaked all over. Topped it off and it's fine.
md21722
Mt Juliet, TN
You mostly want to make sure the oil falls down to the sump. So stand it up, turn it over, and don't run it for a few hours. I have moved pumps, holding them by the flywheel and unloader, and they spun over on me. I just mounted them up, confirmed oil level was normal, and fired them up and haven't had any new noises.
