Leaking water neutralizer drain
slowTA
Morris County, NJ
So my water neutralizer drain has this funny plastic fitting on it before it dumps into the main, along with the washing machine drain. There's a window in the fitting that I guess is there to watch the water coming out during the regen cycle.
Somewhere this fitting started leaking and water is running down the outside of the main, obviously making a mess. Cani just dump the hose into the main and secure it, or do I need that fitting for some reason that I can't figure out? If I need that fitting, what's it called?
BillK
Beautiful Southern Maryland
I cant imagine them putting that crazy contraption on there if there wasnt a good reason for it. What brand is you water neutralizer ? Maybe call them and ask where to get a replacement ?
Jlanciani
Home
It's an airgap or anti-siphon fitting. It's there to prevent waste water from getting sucked into your domestic water if there happened to be a loss of water pressure while the drain valve in the neutralizer is open.
larry4406
Northern Virginia
Sorry for this poor photo but it’s an air gap for a water softener discharging into a waste standpipe. I thought it was a clever piece. Glued and threaded. Not sure who makes it.
slowTA
Morris County, NJ
Thanks for the info. I wound up taking the cheap way out, trimmed down the fitting so the whole thing fits in the main and secured it a bit better. Unfortunately water was pooling up on the board behind one of the windows (I guess it was mist or splash from inside), so I I made a foil funnel to keep it off the wall and in the drain.20221014_134207.jpg
