Learned what not to do
scout4bta
Willcox Arizona
I was measuring the length of the EMT for wire length as I had several mostly used spools, didn't want to run out durning the pull.
Didn't see that the shop vac was plugged in. Didn't see that the plug was ever so slightly pulled out from socket.
Pulled the tape measure over the top of the elect box and went to the other end to take the measurement.
I did see the flashes, one in front of me when the tape measure contacted the conduit and the other from where the metal tape made contact with the two prongs of the shop vac plug. The circuit breaker tripped as did the GFCI outlet. I felt nothing other than hurting my pride from making a dumb mistake.
The Cobbler
reminds me of a former boss . they were getting new vinyl flooring on their stairs at home, he pulled off the aluminum nosing and put them on top of an old fridge in the basement. the kind with the clunk shut door.
anyway, one of the nosing worked its way off the fridge and fell down the backside, landing on the fridge plug that was partway out of the receptacle. arced, caught the flimsy 3/16" panelling on fire . lots of fire damage as a result .
teamextreme
Lakewood, CO
That's one of the arguments made for installing receptacles "upside down". Your tape would hit the ground pin and possibly not had this issue.
scout4bta
Willcox Arizona
Interesting, In SE AZ where I just moved to, most of the outlets are installed "upside down". And it's not code forcing the outlets to be installed that way.
Learn something new every day.
Thanks.
Zmann
Arizona
Tucson AZ building code enforcement looks for ground prong up at receptacles the locals swear all day long the rest of us are doing it wrong phx and area either going to be ground down and no inspectors check for orientation
Zmann
Arizona
The natural way most people grab a plug to unplug puts your lower finger across the hot and neutral with a flipped outlet
apparently I was told by the Tucson electricians there is a area in the NEC that leaves some interpretation gray area on this ( just hearsay on my end though)
75gmck25
Alexandria, VA
Ground terminal up or down on receptacles is not specified in the NEC. There may be local code or rules to follow, but I've never seen any in my AHJ.
Bruce
alfredeneuman
Fullerton, CA
This is a running joke on the pro forums. Anyone asking the up/down (or right/left) question will be ridiculed by the others, and will eventually be locked and removed.
There are no mentions of orientation in either the NEC or the IEC.
Hospitals are subject to there own Codes, in addition to local Codes. They require the ground pin to be up.
scout4bta
Willcox Arizona
I guess we "could" take a cue from the UK and insulate half of the plugs as in the photo.
That ain't going to happen, those must cost a small fortune to manufacture, solid pins and all regardless of the voltage.
CoogarXR
Reminds me of my old 87 cougar with the 5.0. I had one of those batteries installed that had top and side posts. The car was connected to the top posts, and I had a big stereo connected to the side post. When you pull out the mile-long dipstick without paying attention, it will hit directly on the (+) side post.
egdede
I put ground-pins up in our kitchen on the open counter. My wife made me turn them around so that 'they looked like faces again'. I installed the outlets under the cabinet sideways with the neutral wide slots/blades on top.
nadogail
Coronado, CA
While working as Marine Electrician and building ships, I was told that the ABS (American Bureau of Shipping) required the grounds be installed up for the reasons discussed here.
Jim_No_Garage
Millington NJ
Ground down and you can do this to the plates:
Do we need to commission someone to do something similar for ground up orientation?
Cheers
Jim
Antoin
Ireland
Do standard sockets/ outlets in the US not have a switch?
I've never seen/ heard of anything like this happen personally over here. Not that it ever hasn't to someone.
Also very hard to dislodge a plug from our socket even by yanking on it due to the wire coming in at the bottom of the plug unlike the US that has it coming out the back of it.
Sent from my Moto G (4) using The Garage Journal mobile app
dscheidt
t
No. US outlets are not switched at the outlet. some are installed with a wall switch controlling them, so a lamp can be switched on and off. Usually, but not always, only one of the two outlets is switched. We don't have fuses in plugs, either.
cmandp
New Jersey
I've come to the belief that U.S. plugs are not very safe. It's very easy to accidentally touch the hot or neutral while plugging or un-plugging a cord.
As the OP pointed out with UK (or any other European plug) the hot and neutral are insulated so even if you do touch them while partially plugged in you won't get shocked or create an arcflash. Now they do need to be safer because the power is 240v instead of 120v but still 120v could kill you...
infinite97
Vancouver, WA
Just grab the cord and yank like most people!
LS6 Tommy
Northern NJ
Bruce
X2. No NEC code that dictates ground orientation. Engineering documents or building owner specs are what usually call that out.
Tommy
