Liftmaster with Blue learn button
mmrodcrafters
Hello,
I am in need of a remote replacement and the model opener I have is the Liftmaster Formula 1 with 433mhz receiver. I'm hoping someone on this forum may be able to point me to a site where I can purchase a remote? The Blue learn button seems to be quite a unicorn out there and I can't seem to easily find a remote that will work with this model. Thanks for any help you may be able to provide.
Thank you
jstroede
Kansas City
These have been discontinued for quite some time. The remotes like the 893MAX are Liftmaster's universal remote that work for most of their products since like 1993, but I do not know if it will work with yours. You might have to reach out to them, or the one I linked above should be what you need.
John
jstroede
Kansas City
Also, this might give a little more information
It says that the blue learn button openers are not compatible with the MyQ add on, so I would guess that the MAX remotes won't be either. It does sound like you can add the wall control and the MyQ though if you wanted to go that route.
John
kbuhagiar
Escondido, CA
Hello,
Thank you
Boy, you're not kidding.
Apparently the 433mhz units were at one time used in locations with heavy radio signal interference, is that correct?
I found these online, they are 433mhz but not sure if they will work for you're application...
They're cheap enough, maybe give it a shot?
There are others, too, just search using the term '433mhz garage door remote'.
Good luck!
Jsf721
LI, NY
Got the lift master one and sucked. Got tbe no name off Amazon and it’s been great. Mine was a green button
