Light Bulbs
Fudog
Weirton, WV
Good morning, Does it really matter if a 75 or 100 watt bulb is used in a standard 1 bulb fixture that usually has a 60 watt in it? Thanks:dunno:
Norcal
YES!!! It does matter overlamping damages the fixture & burns / overheats the wiring. They are designed for a maximum wattage & it is unwise to disregard the ratings.
ForceFed70
BC, Canada
You would probably get away with a higher-wattage CFL replacement. IE: A 100W CFL equivilent bulb in a 60W max fixture.
But like Norcal mentioned, you risk damage and fire by putting a higher wattage bulb than what the fixture is rated for.
MoonRise
Yes it matters.
Heat from the wattage and amperage through the fixture's wiring. Exceed the rating, and you may have a fire (directly from the heat or semi-indirectly from the wiring melting/heating and starting a fire that way).
Check the rating on the fixture/device and use it within its limits.
re: CFL Don't use the 'wattage equivalent' to determine if the 'bulb' is safe for the fixture, just use the actual real watts.
But also check the rating/limits on the CFL itself, as some did/do limit/restrict usage to non-enclosed fixtures/devices and/or base-down orientation only.
So, it pretty much boils down to RTFM. :D
ddawg16
S. California
When using incandescent bulbs, it's easy to figure out how much heat your getting from the bulb.
A 60w bulb puts out about 60 watts of heat.
A 75w bulb puts out about 75 watts of heat.
A 100w bulb puts out about 100 watts of heat.
A fixture rated for 60w can not have anything in it that will generate more than 60 watts of heat.
sambelcher
:D
If you look at the "real watts" used by a CFL, and pay attention to other limits (base down, etc) then I think you'll be fine.
A CFL that draws 40-60 watts puts out a lot more light than a 60 watt incandescent, and considerably less heat.
ddawg16
S. California
To expand on that....a 23W CFL puts out the equiv of about 100w of light.
Highbeam
Mt Rainier foothills, WA
A regular single base fixture is seldom limited to 60 watts unless you have some sort of chinsy schminsy ghetto fixture.
Does it have a rating sticker?
