Lighting advice - 2.5 car garage
pnut
New garage attached. 25x25 with 9' ceilings. Epoxy floor, high gloss drywall, heated.
Last house I used T20's (4-8' fixtures in a 4 car garage). I want as much if not more. The light was VERY key to being able to work on my vehicles in the garage. I very rarely used portable lighting even underneath working on my vehicles.
I currently have 2-T20's temporarily mounted, another in the basement, and planning overall to do 4 of them. I want maximum light to reflect, and potentially to do some accent lighting around the perimeter so I am looking for suggestions honestly.
Here is what I need help with:
- I read somewhere here that T20's are old tech, but I already have 3-8' units would like to use. What is the new alternative, and why?
- Are 4-8 foot T-20's enough? I think probably since that is alot of light. Just curious on this forum's opinion. Honestly I am hoping someone replies with some unique layouts of lighting to give me ideas. Do I mount them all lengthwise, or due to the way the light is thrown, should I turn some 90 degrees?
- If I put some small cans in the ceiling all the way around the perimeter, can I put insulation above the cans? Maybe cool CFL's or smaller low voltage ones, dunno. Ideas welcome.
Side note, I am really considering putting in new cabinets floor and wall. If I do that, I would put under cabinet lights, and some really cool color glowing LED's at the kick panels hidden shining down at the floor.
amolaver
i've got a similarly sized attached garage and put 6x two-bulb 4' T8 fixtures in it (so 12x 4' bulbs, == 48' of T8 bulbs) and find it to be extremely well lit. i laid them out in two 'U' - one along each side of a car parked in each bay, and one at the front perpendicular, 'across' the hood. if possible, put the fixtures 'outside' of the raised garage door so if the door is up it doesn't block the light. i think the bulbs themselves make a significant difference in quality + amount of light. the philips 6500K bulbs i'm using now are great (10pks at HD are $25).
i'm not familiar with T20 tubes - are you sure you don't mean T12 (1" tubes)?
ahm
Stee6043
West Michigan
What is a "T20"? How old are they? I couldn't even get a straight answer from google. I'm guessing they are pretty vintage?
I don't know what kind of output you get from the fixtures you already have but I tend to think (4) 8 footers might be a bit underwhelming in your garage. My garage is only a little larger and I have (6) 8 foot and (4) 4 foot T8's. I find it to be perfect. T8's are, as far as I know, pretty much the current golden standard for non-highbay applications. T12's are soon to be obselete and T5's will make you go blind with 9 foot celings...
P
pnut
Yes t12. Sorry for he confusion. Had them for years and like them because they are the brightest thing I could find.
T12 x 110w to be specific.
