Little old compressor
wfopete
Somewhere North of Dover, AR
Scored myself this primo find over the weekend on FB market place :)
Fired it up and it shut off @70psi (thankfully). Powered by a massive 1/3h.p. Craftsman motor. Note the indusial strength lamp cord/switch feeding power to the beast. No drain on the tank either. Spray bombed Battleship Gray. Where would info be located on the compressor; the underside of the base?
I have no need for it but for $20 I couldn't pass it up.
lilredex
Toronto
Oil the motor and check the oil level on the compressor head. It'll be good for pumping up tires and maybe powering a small spray gun. Very good deal for $20.
KwikFab
Central Valley, CA
Not bad! I'd ditch the tank though since it has no drain. Easy to swap out and keep everything else.
Could even repurpose the old tank for a small grill.
