Locating PEX in floor
nate379
Palmer, AK
Is there any easy way to locate PEX lines running in the floor?
I'd imagine an thermal imaging camera would do it, but without spending $5000 on one, is there anything else?
69charged
carberry, manitoba
my buddy used a laser thermometer. the kind you buy at home depot. watched for the temp rise as he scrolled over the floor in the area he wanted to drill into.
clarence
N
nate379
Palmer, AK
I see that scanner will scan for rebar, but I think my slab has wire mesh and I have no idea how it's tied into that, if it is even.
Water on the floor will just make the floor wet. I know what your thinking, but it doesn't work that way. Where the pex runs and the surrounding slab doesn't have that much of a temp difference where you could see it with water.
N
nate379
Palmer, AK
I do know the direction the pex runs because when I put the epoxy down on one section the heat was on and it showed then, but the heat wasn't one when I did the rest of the floor.
I need to run some Tapcons into the slab for a wall and I have no idea if the pex is in that area or not.
