Long hex sockets. Would you get ball head?
BrokewrenchLS1
WV
The ball head lets you turn the fastener without the shaft of the hex key being perpendicular to the fastener. They can be useful in some situations.
I have both types; I use the straight-shank for most stuff, as I've sheared not a few of the ball-head style at the "neck", but sometimes they're the only ones that will work.
B_Bimmer
Eastern Iowa
Ball style are significantly easier to break, but also the only thing that works in certain situations. If you are buying them from harbor fright, I would suggest not buying ball end.
90zcar
Ball ends arent really designed for torque. If your fastner is t very deep they can sometimes end up rounding out.
SuzukiGS750EZ
Think of ball end hex as the universal joint for hex. You will really only use them on low torque fasteners at an angle.
southalabama
Brewton AL
I've broken the ball off some of the ball head ones but sometimes you just can't get squarely on the fastener. IMHO both have their place in a tool box. I wouldn't limit myself to one kind.
bwringer
Indianapolis
What we're getting at here is that you need both.
Shocking, eh? You asked the GJ Hive Mind a tool question, and the answer is usually some variation of "buy more tools."
Wamsutta
Amarillo, Texas
Ball hex are not strong enough for breaking a fastener free; they're just for spinning the fastener out after it's loose.
SuzukiGS750EZ
I would get a non hex ball first. I haven't ran into too many areas where I needed the ball style. If you're interested in buying on amazon, look at a company called vim. They make very nice tools and I do believe they make sets of stubby sockets to get into very tight places. You can always add an extension to a regular length socket. I would get a normal length. You can apply more torque and have less of a chance of stripping the bolt. I have an sk set, a craftsman set and a mac set. They're all about equal.
JBradley500
I got non ball long hex socket then just have ball end hex keys when I need that option. I wouldn't mind having both but it hasn't been necessary for me yet.
B_Bimmer
Eastern Iowa
In your case, I would wait until I actually needed them. That'll save you twelve dollars for the foreseeable future.
Koolmoose
Cape Cod, MA
I have both types and find I use the ball headed ones a lot. However, I'm not trying to break loose rusty hex heads. I find them especially useful for tightening the attachment system for Thule rack stuff on the tops of my cars.
Steve
T45
get the VIM over the HF for hex stuff if you can possibly afford it
avoid ball-end hex sockets unless you actually need them (rare)
sockets are needed for torque control primarily, and ball-end is for obstructions
but most applications are designed with sufficient acess
ball end is a bit more handy on an L-key because the shape of the L key
can force the angle off axis, with a socket just use a longer extension
in very, very rare instances the ratchet will be the obstruction
so the ball end is wiggle room.
