Looking for a good radiator hose puller/pick set
monster1
I have a radiator hose pick I bought at hf. It does the job but is kinda clumsy and seems to stretch the hose more than it should because of it's large diameter. I'd prefer made in USA but CO is not an issue if the tools are quality. What do ya'll recommend?
fordnut85
I use a snappy set but of course they are spendy. You might look at Mayhew too.
Rubiman14
Have to recommend the Snappy set as well. I thought I wouldn't use many of the odd shaped picks and I was very wrong. It's an awesome set that I use often. Don't really know of any other equivalents? Maybe look in the truck tool equivalent thread.
DanInVA
I have a pretty nice Craftsman professional set. Sears may be worth a look. The red and black handled pro ones are us made and pretty good quality. You may get lucky and find them on clearance.
Sent from my SM-G920V using Tapatalk
DanInVA
That gearwrench set doesn't look bad imo. However, it doesn't include a large 90 degree, which is the one I would usually reach for. You can most likely use the hook for the same purposes, just my preference.
cliftonbros89
Missouri
Had some large Craftsman Pro picks. Tips kept breaking. Got the Snap On set. Work great. Haven't had a problem yet.
Tron
NoVA
I've seen these hooks and picks before, but wondered how are they used to remove coolant hoses? Can anyone give me a primer?
Monte
Germany
zmotorsports
Northern Utah
I bought a single Snap-On radiator hose pick many years ago and used it so much that I gave the single to my son and bought the complete set. I use the hell out of it and highly recommend it.
Mike.
Brownsfan
Cleveland Ohio
I have the Snap On set. I don't really ever use them for radiator hose tools all that often. Doing automotive electrical various types of hooks and pics come in very handy. Very comfortable to use and fit my hands nice. I have the Craftsman pro set in my service van tool set and no complaints about them at all. The lisle set looks good for the money. Doing it over I don't think I would have bought the Snap On set. Just too pricey for how often I use them.
blarf
Are those the stinky CAB handles or something better? The deciding factor for me between Snap On and PB Swiss was that the snappy ergo handles obviously won't stink up a toolbox, and I was unsure about the Swiss ones.
jerseykat1
Central New Jersey
I've seen them and always just dismissed them as unnecessary. But if it saves me some time and effort I'll have to give a set of these a try.
Sent from my Nexus 6P using Tapatalk
chrisnazzy
Arizona
I opted for this Snap On set instead of the big 6 piece set....
https://store.snapon.com/Soft-Grip-Hose-Picks-Set-Radiator-Hose-Pick-Heavy-Duty-3pc-P646488.aspx
The 90 degree and 45 degree picks work for almost all hose and the smaller hook can also be used to pull even the largest cotter pins
If you wanted an additional hose pick for pulling you could buy this one separately.....
https://store.snapon.com/Soft-Grip-Hose-Picks-Pick-Radiator-Hose-Soft-Grip-9-51--P646480.aspx
The lisle set also looks like a nice complete set and obviously at a much more affordable price. Just an FYI, the Snappys are very proudly labeled USA on each handle if COO is important.
Fedwrench
Valley of the sun
I think anyone working on cars should at least have a long one and a short one. You can use them on connectors,clips, retainers, and hoses too :lol:
Proto has some nice short ones. Their long ones they kind of missed the mark with. Gearwrench just came out with a four piece long heavy duty pick set.
The lisle set offers a lot at a decent price. Mayhew has a couple of sets but, i don't care for their handles but, that's just me.
Titan makes a nice short one with a great trilobal handle for less than $8. Shop around for something handy that fits in your coolant covered hand well.:thumbup:
mdtaylorjr
I bought the Cornwell set because at the time they were only $20 good set and they hold up nicely.
stage20
pcola FL
i have some mac, and a set of the craftsman pros. they work good for me. no tips broken yet.
the issue with the craftsmans is my local store now stocks the taiwan replacement.
make sure they are usa before you spend the money on them if you decide on craftsman.
Askme42
Goreville IL
I'd bet money mayhew is the maker of those craftsman pro sets.
Buster21
Idaho
I just made my own out of an old screwdriver. If for some reason you have to reuse the hose the pick style tends to poke holes in the hose where the one I made does not.
Monkey Milk
Hawaii
This, I have the snap on and the craftsman set. The best I ever used was a shop built one. Made with a long screwdriver, heated and bent backwards. :beer:
Dirtydan69
San Tan Valley, AZ
I have to admit I've used that same trick quite a few times. I made a super slim pick out of a mini screwdriver once. I had someone sabotage a lock once with a broken toothpick. I had no idea it was there until after I inserted the key which pushed the pick deep into the cylinder and not allowing the key to line up. The pick I made pulled it right out.
jteck75
Benton Ky.
I have the Lilse set, I think I bought it at O Reilly's. Its been pretty good so far. Just about anything I've got that Lilse makes/markets has held up really well.
John in OH
SE Ohio & Eastern Virginia
Nice!
Are both of the 90d bends in the same plane?
Did you grind anything off the blade to "smooth" the edges?
Do you think a round shank would be better than the square shank?
Buster21
Idaho
Nice!
That's kind of hard to explain. I bent them at a 90d but then I bent the tip down then back up a little to give it kind of a offset. I debated about square vs. round but decided on the square for strength. I just put it in a vise heated it up and it bent like butter.
