Looking for a Ultra Quick Cure Epoxy Coating
TheGarageMonster
Hi guys just signed up on here, my industrial epoxy flooring in my home workshop is about 13 years old and needs to be redone, mostly staining, scrapes etc. the product i used back then was a Rust Oleum Industrial Coating, it was solvent based and we scarified the floor and it has worked amazing for the abuse i put it though.
I want to redo the floor again by scuffing up the current floor using a floor buffer with a red scotch brite pad. I am seeking a product that kicks and can cure super quickly for foot traffic. Can anyone suggest if such a product exist that cures in a few hours rock hard? I do not care if the coating needs to be squeegee on or a thick paint, doesnt matter but i can handle the application.
cost is not an issue for my investment here but i looked into the plastic flooring solutions and I just do not think it is right for my needs and use of the space.
I need to rent 2 storage PODS to leave outside for all the tool boxes and gear inside so i can do this. it is dead of winter where i live now and need a project to keep me sane.
any product suggestions please post them below or PM me direct.
thanks again
helterskelter
I just did Nohr-S in my garage and am overall happy with the results. It's been so cold the best I could do was ~60 degrees floor temperature measured with IR thermometer. It took ~3-4 hours for re-coat time (light foot traffic) and was fully cured within the ~36 hours per the instructions. It is still a little soft between the re-coat time and full cure so I didn't move anything because I was worried I would imprint the floor (you can mark it with a fingernail).
Next garage I would do full flake broadcast for easy repairs in the future (mine is heavy flaked which should be OK for repairs). I would do extra coats of clear (~3-4 total) Also I would give myself a full 2 weeks to get everything done. I got in a hurry and ended up having to go back over it and do some minor repairs (using heavier flakes to cover it up) and at the same time I put down more clear. So it took me longer than expected because I got in a rush. But it turned out even, has nice gloss and depth and dried extremely hard. Looking forward to getting my small shop back up and running.
